Setting pinion depth
Old Jan 26, 2003 | 08:47 PM
boosted-lt1's Avatar
I was wondering if anyone could help me. Is setting pinion depth that "big a deal". I've seen guys just re-use pinion shims when swaping gears in to the same housing.
This is my first gear swap and I'm not sure if I can just reuse the shim thats on the pinion or will I need to use a depth setter. I was going to re-use the pinion shim and adjust the backlash. Any thoughts?
This is a (1995) GM 7.5 rear.
Old Jan 26, 2003 | 09:04 PM
Use the shim depth that you took out to start with. When you are checking your pattern, you might need to change it. Your pattern ultimately determines the depth as I understand it.
HarleyZ28
Oct 5, 2015 06:23 AM
shroyvin56
Apr 19, 2015 09:40 PM
siguy
Nov 27, 2014 10:07 AM
kev93z28
Aug 19, 2002 12:48 AM
