Setting the oil pick up tube
Old Feb 19, 2006 | 03:53 PM
Radd's Avatar
How do you know the proper level to set the oil pick up tube?
Thanks to anyone that helps.
Old Feb 19, 2006 | 04:43 PM
Mindgame's Avatar
Question Re: Setting the oil pick up tube
I always set the pickup 7/16-1/2" off the bottom of the pan.
Are you asking how to do it, or what the distance "should" be?
-Mindgame
Old Feb 19, 2006 | 04:51 PM
Radd's Avatar
ive never set it before if you have a way to do it i would like to try it
Old Feb 19, 2006 | 04:54 PM
firebirdStud's Avatar
just set the tube in there, and position it so you know the pan will hit it. Then set the pan on it, and push down gently until the pan rests evenly on the block. Then take the pan off, and adjust the pickup down another half inch, and whalaa!!
Old Feb 19, 2006 | 05:14 PM
Mindgame's Avatar
If you have a square/rule combination, you can measure from the bottom of the pickup to the oil pan rail on the block. Remember to subtract the gasket thickness if it's not on the block already. Record that measurement.
Now lay a straight edge across the oil pan rails and measure from the oil pan rail to the bottom of the sump. Subtract your straight edge thickness from your measurement.
If you don't have a square/rule combination, you can use a piece of clay. Put a piece of clay (smaller diameters are easier to smash) on top of the pickup. Place the oil pan on the block and press it flat to the mating surface of the block. Pull the pan and check the clay thickness. Keep the gasket thickness in mind.
And on your pickup height.... I always run an aftermarket pan with more capacity. With a stock pan, shoot for 3/8 to 7/16".
-Mindgame
HectorM52
Jul 30, 2017 11:46 AM
blac94Z
Feb 6, 2015 10:40 AM
alphaauto
Jan 23, 2015 07:42 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
