setting my valves???
Old Jul 28, 2003 | 02:27 PM
red95lt1's Avatar
alright, i have set them about 5 times and have used alot of different techniques, but none of them seem to work. What is the best way to do it. I have a 95 ta with the lt4 hotcam kit, with roller rockers and polly locks.
Old Jul 28, 2003 | 02:36 PM
sssalah's Avatar
How did you set them? what makes you think they're not set properly? SA roller rocker are normaly noiser. Anyway, I set mine with engine off, then start engine and recheck every one by loosining it till it tick and then tightning untill its quite. I then turn it 1/4 turn to lock it in place.
Old Jul 28, 2003 | 02:42 PM
red95lt1's Avatar
i have set it many different ways, one way it was a friends way that i dont know how he did it, then i set mine with the engine on and when loosened it till it ticked and then tightened it back till i could hear any more and then i did a half turn. Then i locked it with the polly lock.
The other way was that i did the spin the push rod and then when i got it to stop spinning i bumped the car over and set every valve by there self and also did the half turn.
the reason i think my valves are off is that i have no power from 0-3000 rpms. If i take a turn i cant even make it fishtail. I used to make if fishtail with only half the gas. Also it is idiling at 500 sometimes.
Old Jul 28, 2003 | 04:11 PM
red95lt1's Avatar
ttt
Old Jul 28, 2003 | 04:29 PM
slashz28's Avatar
k. here ya go. failproof method my friend
go TDC #1 . ( do a search on Shoebox's site and itll tell you which ones to set , sorry bout that).
dont go by the "spin the pushrod" method. go at it by moving the pushrod up and down while tightening, till theres no more up/down movement. it WILL still spin though. tighten 1/2 turn past that and tighten the poly. thats it
half are done at TDC#1 and the other half at TDC#6. ill do a search and get the right ones for you. hth
Old Jul 28, 2003 | 04:35 PM
slashz28's Avatar
k. im back again
here goes:
TDC#1--INT-- 1,2,5,7
EXH--1,3,4,8
TDC#6--INT--3,4,6,8
EXH--2,5,6,7
hth
Old Jul 28, 2003 | 05:02 PM
red95lt1's Avatar
alright, i am an idiot, how do i set it to tdc #1 and #6
and also which ones are the intake and which ones are the exhaust valves?
Thanks for the help slashz28
Old Jul 28, 2003 | 05:14 PM
slashz28's Avatar
i pmed you back with the answers youre more than welcome
Old Jul 28, 2003 | 06:55 PM
red95lt1's Avatar
one last question i hope, How do i know when it a cylinder is a tdc, i mean is both exh and int. pushrods down or up?
I already tried the tdc #1 and #6 and i set everything and it made all kind of noise. So i guess my hub has came off before i bought the car.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
