Ses To Pcm Wire
Old Jun 9, 2007 | 02:02 PM
sean-k94z's Avatar
Ses To Pcm Wire
Hi, I'm tying to use my in-dash SES light for something els. Does anyone know what wire from the PCM triggers the SES light. I have looked at a few schematics but I cant find anything labeled service lamp. All I could find was skip shift lamp. Any ideas?
Thanks,
Sean
Old Jun 9, 2007 | 02:03 PM
shock6906's Avatar
Curious...what are you going to be using it for?
Old Jun 9, 2007 | 05:21 PM
sean-k94z's Avatar
I have an after market knock detection system I want to use. I want the engine light to flash when knock is detected.
Old Jun 9, 2007 | 07:34 PM
Projectz28's Avatar
Moderator
You may have to wire a relay into it to drive the light. The SES has a constant pos to it and the PCM grounds the circuit to turn on the light. I forget which wire it is but I can go look in my service manual later tonight or tomorrow for ya...
Old Jun 9, 2007 | 08:09 PM
Thanks,
Sean
Did you look for "MIL control"? That is what it is called. On a 1994 PCM, it would be D9 (that's the blue connector).
Old Jun 9, 2007 | 11:56 PM
sean-k94z's Avatar
awesome, ill give that a try. Looks like grounding D9 will trigger the light.
jayvar
Feb 2, 2015 10:00 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
Jan 5, 2015 07:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
