SES Light WTF!
SES Light WTF!
My SES light comes on at higher speeds (~60mph) .. and it stays on. I shut the car off, and it goes away. Then, when i get back up to 60, bam, on again. The car feels a little funny up there, too. I had it scanned, nothing showed up. Any opinions on whats wrong?
Re: SES Light WTF!
its a 94, with LT headers, hotcam, gears, cai, etc..
ive also noticed it gets real shaky up near 80MPH.. vibrates my legs lol
this happen to u too, whoever had same prob and was o2 sensor?
Re: SES Light WTF!
My Z did the same thing except it did set a code, it was for EGR. To test the valve pull the vacuum line off the valve, take your fingers and push up on the diaphram then plug the vacuum port on the EGR valve, release fingers. If the diaphram falls down with vacuum port plugged it is defective.
Re: SES Light WTF!
Originally Posted by DataChild
.....I had it scanned, nothing showed up. Any opinions on whats wrong?
Re: SES Light WTF!
well, the light was on, he turned the motor off, then he did some things with the pins, resetting stuff or something... u know the paperclip thing? he did the same thing only with this 2$ tool.. then he scanned. now that i think about it, wouldnt that reset the code? ahh crap
Re: SES Light WTF!
No.... you can NOT scan a 94 by shorting the ALDL connector pins, and no, shorting them will NOT reset the codes. 1993 was the last year you could retrieve the codes by doing that. You need to use a "real" scan tool to pull the codes.
Re: SES Light WTF!
Yea.. so heres an update... I was 100% sure it was EGR valve due to symptoms i read on other posts.........
then it dawned on me. I bought the car and it already had long tube headers, so the egr must be blocked off. sure enough, i check back there, and its definitly blocked off, however the EGR valve is still there. there is a little rubber nipple thing at the top. I duno if thats good or not...
So now im back at thinking this is o2 sensors. if anyone could re-read the problem i would love u forever! and ever...............
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Z28Wilson
Aug 1, 2002 04:27 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
