SES light at ful throttle?
Old Jul 31, 2005 | 10:18 PM
Black6spdZ's Avatar
My check engine light comes on sometimes at full throttle and goes back off when i return to a cruise. I scanned the codes and it said that TPS voltage high, so i put a new sensor on it and still same problem. With the scan tool hooked up and the pedal to the floor it reads 4.80 volts. I thought that was what it is supposed to be? Any ideas are appreciated
Old Jul 31, 2005 | 11:25 PM
Re: SES light at ful throttle?
You might be seeing a slightly higher voltage when the engine is actually under load (as opposed to sitting in your driveway). According to the manual I have, the code (P0123) for TPS circuit high voltage sets:
Monitor Strategy:
Circuit continuity detects a continuous short to high in the signal circuit for the TP sensor.
Malfunction Criteria & Threshold Value:
Raw TP sensor signal is (greater then) 245 A/D counts (4.9 Volts).
Secondary Parameters & Enable Conditions:
-Ignition on
-Condition present for 1 second
Time Required & Frequency:
-90 test failures in 100 test sample
-6.25 msec/test
-Continuous
Try and get a voltage reading at full throttle on the road.
Old Jul 31, 2005 | 11:27 PM
Black6spdZ's Avatar
i will get try to get one sometime this week. the voltage readings were taken with the engine off and key on through a scan tool
Old Jul 31, 2005 | 11:32 PM
What is your open throttle voltage? If its pushing 0.90V, you could slot the holes and back off to 0.50-0.65V. That is a common problem with some 58mm TB's.... I ihad to slot the holes on the TPS with my Holley 58mm.
Old Jul 31, 2005 | 11:40 PM
Black6spdZ's Avatar
i am not 100% but i though it was .5x
Gtpguy
Jan 26, 2015 04:50 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
