SES Light & Fans
Old Jan 23, 2003 | 07:42 AM
Moose's Avatar
SES Light & Fans
Hi all,
I have been having this problem for a while now and need to fix it. After I turn my car on and it runs for 30 seconds to a minute, I hear one fan turn on, then the SES light comes on, then the other fan turns on and the SES light stays on until I tunr off the car. I scanned the code (my car is a 93Z28) and it is 26. Last night I did some research on here and checked, and the fuse for the AIR pump was blown. I replaced it and the problem continues. I will check today and post back if it is blown again. Give me some suggestions on troubleshooting ideas. Also, how do I do !AIR if the AIR pump is the problem. I'd rather just remove it than replace it, but I want that dang SES light to stay off!
Thanks!
Old Jan 23, 2003 | 08:16 AM
The fans come on as a result of the SES. The computer does that. If you are blowing AIR pump fuses, just disconnect the plug to the pump. I can't quite remember, but I think it will not cause the SES if you do this on your 1993. You can try it, at least. Your pump is probably suffering from corrosion that is causing an internal short.
Old Jan 23, 2003 | 08:43 AM
Moose's Avatar
I assume you mean the power source to the pump? Or is there some sort of sensor?
Thanks...
Old Jan 23, 2003 | 09:58 AM
Thanks...
Yeah, there is a small electrical connector right on the pump. Unplug it.
Old Jan 23, 2003 | 05:58 PM
Moose's Avatar
Okay, I pulled the power to the pump, but the problem persists. What should I do next???
Old Jan 23, 2003 | 07:53 PM
Still SES, same trouble code and the fuse is not blown? Maybe someone that has actually gotten rid of the AIR pump can chime in. Sounds like you don't want to replace the pump.
Old Jan 23, 2003 | 07:56 PM
Moose's Avatar
The fuse was blown and I tried to just unplug the AIR pump and the SES light is still on. I can replace the pump if I can verify that is the problem. But, if it can be fixed without being replaced, that would be better
Old Jan 23, 2003 | 08:05 PM
Just to be straight, the fuse needs to be good and the pump unplugged.
Old Jan 24, 2003 | 07:37 AM
Moose's Avatar
I think that did it. I just got to work and the SES light (nor the fans) ever came on. So for some reason it needs a fuse to be in there even though the AIR pump is unplugged, eh? THanks for the idiod check and advise!
Old Jan 24, 2003 | 09:03 AM
JWA95TA's Avatar
check this link out, might be of some help too
A.I.R PUMP
Jason
Old Jan 24, 2003 | 10:10 AM
Moose's Avatar
Thanks, but I think I am just going to remove it now...
Magenta_Hearts
Mar 29, 2017 08:54 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
