SES light and fan on high
Old Aug 9, 2004 | 08:45 AM
hawk29's Avatar
Question SES light and fan on high
I have a 95 firebird formula /firehawk (A4, 30500 miles) and twice yesterday upon start up my SES light came on and the fans were running on high speed. Each time after I turned the car off and back on It was back to normal. The first time it came on i just drove around the block after washing the car. After restart it went out and car ran fine. The other was for 50 or so miles and then I stopped and restarted the light went out and drove 200 miles home with no problems. The car seemed to run fine with light on except for the fans on high. I will also add that between the the SES light coming on i was at the Ames pontiac nationals and the car ran 14.0X ( 2.19-60 ) the same as it had the last I ran ET's 4 years prior. Any Ideas on what could be the problem? I will try and get it scanned this upcoming weekend to so if any codes were storred. Thanks in advavce
Old Aug 9, 2004 | 09:00 AM
Re: SES light and fan on high
The fans are supposed to come on when the SES does, so don't be thinking those are two problems.
The scan will tell you what you need to look at.
Old Aug 9, 2004 | 09:04 AM
88irocz28's Avatar
Might want to check your AIR pump fuse. It's apparently the most common cause of SES light on/fans on high syndrome.
Gtpguy
Jan 26, 2015 04:50 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
