SES light on expressway - probably EGR?
Old Sep 12, 2003 | 10:14 AM
PatriotTA's Avatar
OK, I removed my EGR system and put a resistor in the connector. Lately, I have had an occasional SES light that will come on while I'm on the expressway, cruising about 70-80 mph. It will usually go out when I exit the expressway and stop, then cruise about 45 mph or so. I took it to the track not too long ago, and didn't set the SES light while racing or on the way home (expressway). Any ideas? I am planning on getting a laptop with scanning software, but money's a little tight now.
Old Sep 12, 2003 | 10:38 AM
madwolf's Avatar
Try to find someone in your local club with a laptop and cable and scan it. It's the best way to find out what the code is.
It's just not worth taking guesses since there are 100 codes and it could be just about anything.
From what others described though, it sounds like EGR...maybe CCP. What resistor value did you use and how did you know that was the value you needed?
Old Sep 12, 2003 | 11:08 AM
PatriotTA's Avatar
I had used a 2.2k ohm resistor, I had read that was the correct value somewhere (probably on this board). I'm not too worried about it, but it would be nice to know.
Old Sep 14, 2003 | 03:25 AM
scoobysnax83's Avatar
It probably is.... something's loose.
timmy39120
May 8, 2015 11:41 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
