SES light, blowing fuse
Old Feb 17, 2003 | 05:37 PM
PaulN64's Avatar
took my car to get the code read and here's what I got
P0100
The PCM has determined that a malfunction exists in the electrical circuit for the mass air flow or volume air flow sensor. This code points towards a possible wiring problem, IE : short to ground, short to power, or an open circuit.
checked the fuse under the hood and the eng sensor was blown. ok, here's the deal. Replaced the fuse and cleared out the code. Took it for a test drive and it was fine till the rpm went over 2000 rpm, there was a surge and SES light came on and the fuse had blown. Any ideas?
Old Feb 17, 2003 | 06:29 PM
PaulN64's Avatar
ttt
anyone?
Old Feb 17, 2003 | 06:32 PM
RamAir95TA's Avatar
Possibly a faulty MAF sensor. With the engine running, tap on the top flat portion of the connector on the side of the MAF and see if it changes engine running behavior. If so, your MAF is bad. Check for obvious indications that your MAF took a dump too (i.e., missing sensor leads inside the MAF, broked/disconnected wires, etc.).
Old Feb 17, 2003 | 06:35 PM
PaulN64's Avatar
I won't have chance to do so tonight, but I was going to swap out maf with my friends 94 Z and see if I still throw a code/blow a fuse. I'm not sure, but a 94 MAF should be compatible.
Old Feb 17, 2003 | 06:38 PM
RamAir95TA's Avatar
That would be a good idea. MAFs are interchangeable, so you could observe running conditions with his.
Old Feb 17, 2003 | 06:53 PM
Rich_z28's Avatar
If you need a MAF sensor I have one for sale right now. PM me if that's your problem and you're interested. Or get me on AIM. User name is in my Sig.
Old May 9, 2004 | 05:13 PM
1996CAMSS's Avatar
PaulN64...
What did you ever figure out on this problem... I am having the same problem with mine right now. The check engine light came on and the eng sensor fuse is blown... the circuit also controls the reverse lockout on the 6 speed the way it seems as I have major problems as soon as the fuse blows. When I put a new fuse in, drops right in reverse.
Any help greatly appreciated.
Clarke
Old May 9, 2004 | 11:57 PM
PaulN64's Avatar
wow...this was an old post but anyway. What happened was I did the resistor skipshift bypass and the wire just happen to work it self loose and was grounding out which was causing the fuse to blow. After I tape the resistor back up and make sure that there were plenty of electrical tape around the resistor, everything was fine. So I'm not sure if you had done the same thing to your car, but that's how I fixed mine.
Old May 10, 2004 | 04:47 AM
1996CAMSS's Avatar
Thanks for the info... that isn't my problem, but I am sure I must have a wire grounding out. I installed a new starter and this started blowing the fuse a day later. I tied the wires back from the headers and I didn't see any wires touching, but there has to be one touching somewhere.
Thanks again for the response.
Clarke
Gtpguy
Jan 26, 2015 04:50 PM
fpete1992
Dec 11, 2014 03:51 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
