SES Light Blinking
Old May 7, 2007 | 05:54 PM
Camaro1996's Avatar
SES Light Blinking
Well my car has been hesitating a bit lately, and today the SES light started blinking. Apparently this means it was badly misfiring. When the light started to blink, I let up on the gas and drove it easy. What could this mean? The plugs were replaced around 15,000 miles ago, but not the wires. Is it possible the Opti is starting to go? The car has 94k miles on it. Should I not drive the car until it is fixed?
Old May 7, 2007 | 06:38 PM
moparman's Avatar
You need to have the code(s) pulled. Take it to Autozone and have them read the code(s). Be sure to take note of the exact code number(s) and post them here.
Old May 7, 2007 | 06:53 PM
gitsum's Avatar
Mine did that a while back, so I checked the wires and one of them was burnt by the headers. I got new wires and that took care of it. But I agree with moparman, take it to autozone.
Old May 7, 2007 | 08:22 PM
Camaro1996's Avatar
Update: I took it to Autozone and the code is P0300: Random Misfire. So I looked around on the net and people say it may be related to cap/rotor, plugs, or wires. I might buy that MSD cap and rotor, but its somewhat expensive. Is it possible my Opti is dying all together?
Also what about fuel? I replaced the fuel filter a couple of weeks ago, but what if the injectors are dirty? I put in some 44K when I changed the fuel filter, but it didnt seem to do an enormous difference.
Old May 7, 2007 | 08:24 PM
2000GTP's Avatar
It could be an ignition related problem with the Opti. It can also be a case of clogged/dirty injectors. I would also check the car over for any vacuum leaks.
Old May 7, 2007 | 09:38 PM
doug1105's Avatar
I would check the plug wires first. Make sure they aren't touching a header primary of getting cut by the pulleys on the passenger side.
If you just changed the plugs, it might be a wire that is hitting a header or a broken boot or old wires with tiny cracks in them.
Old May 8, 2007 | 08:10 AM
ArizonaZ's Avatar
I had the same problem about two years back. After changing the plugs, one of the plug wires was too close to a primary and melted all the wat threw to the core. I would look for that, especially on the passenger side. It might be in a spot that is not so obvious.
Old May 8, 2007 | 11:45 PM
Camaro1996's Avatar
I'm not sure if it is the plug wires, since the car seems to hesitate under ~2000 rpm, not at all rpms. It seems to be fine at higher RPMs. Is it more likely to be fuel since this is the case?
Old May 9, 2007 | 11:46 AM
White96Z28's Avatar
Check your plugs and wires, but the first thing I would do is check the injector pigtails. I've had two LT1's and I've had injector pigtails get loose on both of them. Just a thought before you go through the hassle of changing plugs and wires or digging into the Opti...
Old May 9, 2007 | 01:32 PM
SS RRR's Avatar
I would try to isolate the problem first. W/ the engine running, pull injector clips off the injectors to see if there is one that doesn't make a difference in idle. When you find it it'll make your job that much easier.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
