SES Light Blinking
SES Light Blinking
Well my car has been hesitating a bit lately, and today the SES light started blinking. Apparently this means it was badly misfiring. When the light started to blink, I let up on the gas and drove it easy. What could this mean? The plugs were replaced around 15,000 miles ago, but not the wires. Is it possible the Opti is starting to go? The car has 94k miles on it. Should I not drive the car until it is fixed?
Update: I took it to Autozone and the code is P0300: Random Misfire. So I looked around on the net and people say it may be related to cap/rotor, plugs, or wires. I might buy that MSD cap and rotor, but its somewhat expensive. Is it possible my Opti is dying all together?
Also what about fuel? I replaced the fuel filter a couple of weeks ago, but what if the injectors are dirty? I put in some 44K when I changed the fuel filter, but it didnt seem to do an enormous difference.
I would check the plug wires first. Make sure they aren't touching a header primary of getting cut by the pulleys on the passenger side.
If you just changed the plugs, it might be a wire that is hitting a header or a broken boot or old wires with tiny cracks in them.
I had the same problem about two years back. After changing the plugs, one of the plug wires was too close to a primary and melted all the wat threw to the core. I would look for that, especially on the passenger side. It might be in a spot that is not so obvious.
Check your plugs and wires, but the first thing I would do is check the injector pigtails. I've had two LT1's and I've had injector pigtails get loose on both of them. Just a thought before you go through the hassle of changing plugs and wires or digging into the Opti...
I would try to isolate the problem first. W/ the engine running, pull injector clips off the injectors to see if there is one that doesn't make a difference in idle. When you find it it'll make your job that much easier.
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Z28Wilson
Aug 1, 2002 04:27 PM
