SES light after TB Bypass!
Old Jan 29, 2004 | 06:47 PM
Tair's Avatar
Angry SES light after TB Bypass!
ARGH! So I FINALLY got the stupid clamp off the left side, finished up the TBB and screwed everything back tightly and now I have an SES light after taking the car around the block. The only things I can think of are that I don't have the air filter on yet (it fell off when I was taking off the intake elbow) and I didn't bleed the coolant lines. Any clues?
Old Jan 29, 2004 | 06:54 PM
ibanez6rg's Avatar
MAF and IAT plugged in?
Old Jan 29, 2004 | 07:01 PM
Tair's Avatar
nope, both plugged in....just taking a break now before I reattach the air filter....damn K&N cone
Old Jan 29, 2004 | 07:23 PM
Eliminator's Avatar
You wouldnt think that the TB Bypass would cause that. I bet there is something else. You said the MAS and the IAT are plugged in maybe the elbow to the throttle-body wasnt on tight???
Old Jan 29, 2004 | 08:09 PM
ny_z28man's Avatar
Id check other things and get that code read. the PCm dosnt monitor the Coolant in the throttle body so it shouldnt be throwing any codes. check your coolant level and see if everything is plugged back in right.
Old Jan 29, 2004 | 08:17 PM
Red96Lt1's Avatar
I wouldn't think low coolent would throw a code, just the dash light.
Old Jan 29, 2004 | 08:20 PM
ibanez6rg's Avatar
Maybe you knocked another sensor harness off your TB? I'd go through and check all the connections first.
Old Jan 29, 2004 | 08:22 PM
Tair's Avatar
The K&N filter is back on now. I can't feel any air sucking in at all. Is it supposed to be like this? I figured that was correct, maybe I'm wrong.
Old Jan 29, 2004 | 09:03 PM
Tair's Avatar
Alright, where can I get my car scanned? I have OBD1. The symptom I have, aside from the SES light, is that my car takes a lot of cranking to start now.
Old Jan 29, 2004 | 09:21 PM
Kain's Avatar
MAF and IAT plugged in, what about the TPS sensor?
Old Jan 29, 2004 | 09:27 PM
Tair's Avatar
yep...the two plugs on the throttle body are plugged in....he one on the intake elbow is in....the one on the maf is in.....waiting now to see if resetting the pcm will get rid of the SES light. Please tell me my opti isn't gone. I remember seeing my opti totally dry, and I checked it again after I started up my car right after the throttle body bypass, but I still have doubts because of how common it seems to be that people get their opti's wet.
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i also have the k&n and recently cleaned it. i didn't get any codes but i did notice an audible change. i can hear the air being sucked in from the drivers seat with the window down. if you dont feel any air moving through the filter then somethings wrong with your air intake. i had a bear of a time hooking it up to the maf and making a good seal. IMHO sounds like improper air flow.
Old Jan 29, 2004 | 09:28 PM
shadydavy 95 TA's Avatar
Check all you air pipe connections. Make sure they aren't torn/dry rotted/ripped. The lots of cranking part makes me think you're sucking or losing air someplace you shouldn't be.
Old Jan 29, 2004 | 10:08 PM
Cmr0z28's Avatar
Make sure the intake elbow is COMPLETELY on the throttle body and MAF. Sometimes people put it on, and the bottom part isn't on all the way.
Old Jan 30, 2004 | 08:21 PM
Tair's Avatar
PROBLEM SOLVED!!! Luckily I just received my PCM cable from AKM Cables, since I was planning on getting a madwolf tune later. I downloaded FreeScan and ran it on my laptop and it showed Trouble Code #15 (Coolant Low Temp) It also showed the coolant temperature at -40degrees C (absolute zero), meaning it was either broken or not plugged in. I checked under the hood, and found the coolant temp sensor unplugged. I must have knocked it off when I took off the intake elbow! Thank god I figured this thing out....cranking the car 3-4 times everytime I wanted to start the car was getting annoying.
Gtpguy
Jan 26, 2015 04:50 PM
fpete1992
Dec 11, 2014 03:51 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
