ses light 95lt1
Old Nov 30, 2006 | 11:38 AM
diamondhill's Avatar
Question ses light 95lt1
im getting a random ses light on my 95 ta. the ses light comes on sometimes when i drive it for the first mile then it goes off after about 10 minutes,it doesnt do it every day just sometimes.. when its on i cant tell a difference in the way the engine opperates.. could it be becuase i have my smog pump removed????
Old Nov 30, 2006 | 12:01 PM
davidarel's Avatar
If you didn't have the PCM programmed to account for that, then I would say it is a very likely candidate.
Old Nov 30, 2006 | 05:49 PM
Since you have a 95, its possible to remove the AIR pump, and NOT get an SES light. As long as there is a good fuse in the circuit, it doesn't matter that the harness connector isn't connected to the pump. The electrical circuit is the only thing that is checked in OBD-I.
But, rather than guess, get it scanned to see why the light is coming on. Even if it goes out, the code is still stored in the PCM for a while.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
