ses light
Old Feb 9, 2008 | 07:13 AM
1994's Avatar
ses light
Have you seen this problem before i have 94 firebird v8.dealer check it they said no codes were found .ses light come on both fans,i have change both o2 sensors,new gm distributor.When i change the o2 sensor two years ago the light came on but may be once or twices no problem. one year ago i put in a new distributor an the light on all the time an both fans my second catalytic converter is bad.
Old Feb 9, 2008 | 12:40 PM
CheshireCat's Avatar
Welcome to the board. If your SES light is on and both fans are constantly on, then you should be showing a code when your PCM is scanned by the dealer. You can try resetting the PCM by disconnecting the battery or pulling the PCM Bat Fuse.
You may want to take a moment and edit your original post or post again to ask specific questions.
Also you should take a moment to create a signature file to let everyone know more about your car. Include the year, engine, transmission, and any known modifications.
Good luck.
Old Feb 9, 2008 | 03:50 PM
2000GTP's Avatar
There should be a code or a history code. Also, you mentioned you second cat was bad. Is this the second cat you have replaced, because on the 94, it only had one cat in the y-pipe from the factory.
Old Jun 9, 2008 | 08:49 PM
1994's Avatar
i purchase a scanner an got a code 26. so i replaced the canister purge solenoid no more ses light
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
