Oil level sensor thread size
Old Jun 9, 2008 | 03:35 PM
RUDEDOG's Avatar
Does anyone know the thread size so I can plug it. It's leaking out of the connector and I'm not spending 32 dollars for a new one. I already tried rtv and its leaking again. Thanks.
Old Jun 9, 2008 | 04:12 PM
BCdawg57's Avatar
20 mm
Old Jun 9, 2008 | 04:24 PM
RUDEDOG's Avatar
Thanks I hope I can find a plug that size.
Old Jun 9, 2008 | 05:20 PM
cehan's Avatar
I bought one from Canton because I did away with the level sensor, but later I read on this board that someone found the same size plug (20 mm) at Autozone as an oil pan drain plug for some unknown vehicle.
Old Jun 9, 2008 | 05:31 PM
cnorton's Avatar
That is an accurate statement. Just ask for a 20mm drain plug.
Old Jun 9, 2008 | 09:52 PM
pcgamer4life's Avatar
Yeah, and if they don't know what to look for, tell them to look it up under a diesel engine, some are 22mm (which plug the 5/8" hole in stock manifolds for air fittings) and some are 20mm, depending on year/motor.
HectorM52
Jul 30, 2017 11:46 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
