service engine light?
Old Jan 30, 2006 | 01:00 PM
danny525's Avatar
Question service engine light?
OKay well while hooking up a manual fan switch, my check engine light came on. I made the mistake of splicing into the high speed fan after the relay, instead of before it, and when i did this the light came on. No i have fixed the problem and spliced it in the right spot. But the light still is on. Should the light go off by itself once the problem is fixed? ( cause i hooked all the wires to stock form and it still stayed on) Or do i have to have the light turned off even if the problem is fixed?
Old Jan 30, 2006 | 01:13 PM
danny525's Avatar
Re: service engine light?
or i more simple question as i just read a thread, how do you reset the computer?
Old Jan 30, 2006 | 01:35 PM
MyShibbyZ28's Avatar
Disconnect the battery for a minute or so.
Did changing the wire splice spot solve the on/off problem for the fans?
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jan 5, 2015 07:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Jul 4, 2005 05:00 PM
