serp belt noise.
Old Jul 10, 2009 | 05:46 PM
userchemical's Avatar
serp belt noise.
Okay, ive put on 2 brand new serp belts on my and they both make noise. They both squeal. Before anyone says it might be a pulley, i have a brand new tensioner, brand new alternator and power steering pump. I do not have a/c. If i spray the belt with a bit of WD/40 the noise goes away and stays gone for my car drive. when i turn the car off and it sits a bit, the noise will start again. You can always hear it, kinda like the alternator but it does not sound the same at all..
any idea's people?
Old Jul 10, 2009 | 07:37 PM
I don't understand why people would spray a belt with WD-40. You should be cleaning it of any oils, not putting some on. Junk on the belt is only going to worsen things.
Are you saying you have an a/c delete pulley in place of the compressor? Are you using the correct size belt? Some people have needed to change the belt length with a delete pulley. Have you tried a Goodyear Gatorback belt?
Old Jul 11, 2009 | 10:41 AM
no a/c delete pulley, i have an alternator relocation bracket.
i have a 57.7" belt on it at the moment, it was really tight going on. Started the car up, no noise, sounded good. So parked car, next day get up for work and its squealing. getting to the point where i want to change my set-up again. the 58.5" is to big, couldnt find a 58"
GTR-4060585 - 58.5"
GTR-4060578 - 57.7"
GTR-4060575 - 57.5"
Old Jul 11, 2009 | 09:16 PM
Ricardo's Avatar
Probably your crank pulley is worn. Check a used serpentine belt to see if the pulley is reaching the bottom of the v shaped grooves.
Old Jul 12, 2009 | 10:01 AM
its not the crank pulley. I took the front of my engine apart and cleaned it all with a wire brush then reinstalled everything, noise is now gone.
Old Jul 14, 2009 | 06:19 PM
Noise is back, after car sits and cools down, when i start the car the belt sqeeks. After about 5 minute the noise is gone. What the hell is going on.
Old Jul 14, 2009 | 06:39 PM
Wild1's Avatar
I once had an issue with the power steering fluid pump making noise on start up until the fluid warmed up. I changed the fluid and it went away. Sounds like a belt but it was the pump. Maybe that helps.
Old Jul 14, 2009 | 10:13 PM
hhmm that might explain why when i drive to work in the morning in traffic it takes 5 minutes, but when i drive home with no traffic the noise is gone right after a 3rd gear pull. ill have to check the pump, i know my rack is leaking at the inner tie rod seal.
Old Jul 15, 2009 | 03:20 PM
95Blackhawk's Avatar
Check the alignment between the dampener pulley and the accessories. Best way to do this easily is to check the idler and where the belt sits on the dampener side and where the belt sits on the alternator side (if I understood the alternator is now where your AC used to be).
Old Jul 15, 2009 | 08:34 PM
slomarao's Avatar
I am having a similar problem but I think mines the power steering pulley. It has a bit of play and kind of wobbes. Very little though, its driving me crazy.
How do your belts look when you take them off??
Old Oct 16, 2009 | 05:43 PM
entierly's Avatar
Im having this same problem with my 97 Z28, and I don't know what to do =[ I have replaced the serpentine belt and it is worse than before...
Old Oct 16, 2009 | 05:50 PM
Wild1's Avatar
With the belt off, spin the pulleys by hand. If one does not feel smooth then you may have a bad pulley.
Old Oct 16, 2009 | 07:39 PM
Black396's Avatar
Use a goodyear gatorback belt
Old Oct 17, 2009 | 07:08 PM
94Z28LS1toLT1's Avatar
im having the same problem mine makes a sqealing noise and my bro and i just put in a crate engine and all my pulleys are fine
autoxr166
Sep 25, 2015 04:21 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
