series 2 or 3 carrier?
Old Oct 18, 2003 | 09:15 PM
ddlouhy127's Avatar
do i have a series 2 or 3 carrier? i have a 1995 trans am, single cat. thanks.
Old Oct 18, 2003 | 09:30 PM
aintno6's Avatar
You need to find out first what rear end gear you car has right now from the factory. Best way to tell is go look at your shifter. If there is no selectable 1st gear then you have the dreaded 2.73s like I had. If the shifter has 3 2 and 1, then I think you have the 3.23's.
So if you car has 2.73's from the factory, your car will have a series 2 carrier. If it has 3.23's then it will be the 3 series carrier. Hope this helps.
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
KamikaZ28
May 28, 2015 12:45 AM
May 1, 2015 01:14 PM
