Sensor ontop of rear differential cover?
Friend is doing a 4th gen rear end swap, into a 3rd gen. The rear end he got is from a 93-97 F-body.. There is a sensor on the differential cover, can anyone provide any insight on this sensor?
Re: Sensor ontop of rear differential cover?
Originally Posted by Bryan Smith
ABS Sensor, 98+ had 4 wheel abs sensoring.
Originally Posted by Z95m6
Wrong. It is the ABS sensor, but "4 wheel abs sensoring" AKA traction control which is a 4 channel, could be had on LT1 cars. The rear you have must be a 3 channel non traction control rear end.
Is he aware that the 4th Gen rear axle assembly is 3" wider than the one on his 3rd Gen, and could require different offset wheels (depending on whether his 3rd Gen was one with the factory "spacers")?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
