sensor name
Old Sep 9, 2005 | 02:18 PM
redstriper05's Avatar
sensor name
Anybody know the part name for this sensor in the picture named (optispark)?
http://shbox.com/1/harness2.jpg
Old Sep 9, 2005 | 02:38 PM
Re: sensor name
It's not a sensor, it's the optispark connector.
Old Sep 9, 2005 | 02:46 PM
Re: sensor name
Ok if I need to ask chevy to order it should I just tell them that??
Old Sep 9, 2005 | 02:48 PM
Dave89IROC's Avatar
Re: sensor name
um...
why do you think you need one?
Old Sep 9, 2005 | 02:51 PM
Re: sensor name
The clip broke off of it so it can't snap on and wiggles out and SES comes on and throws a code about to few signals.
Old Sep 9, 2005 | 02:53 PM
TobyZ28's Avatar
Re: sensor name
I belive that the optispark plug is a pigtail... and I KNOW they charge an arm and a leg for this 1' pigtail. (300$ish!!)
Old Sep 9, 2005 | 03:03 PM
Dave89IROC's Avatar
Re: sensor name
nope, if it is for the 96 in his sig, dealer is around $90 IIRC, but it is half that here
https://www.casperselectronics.com/M...Category_Code=
Old Sep 9, 2005 | 03:46 PM
Re: sensor name
You mean the little tit that fits into the bracket broke off? If that's all, use a nylon tie to hold it to the bracket. Maybe when it falls loose, it gets too close to the injector wires and starts to pick up electronic "noise", causing the code (what was the actual code you got?). A lot cheaper than buying a new harness. Unless the plug itself is somehow damaged or corroded, it shouldn't be a problem.
Old Sep 9, 2005 | 04:29 PM
Re: sensor name
Thats the one. I pulled it out and not only is it the clip but the wires right before the connector are eposed so gonna get a new one. Thanks a lot guys, tell ya what if new cars have more computer crap on them I feel bad for the furture mechanics lol.
Old Sep 9, 2005 | 09:43 PM
SnakeOiler's Avatar
Re: sensor name
It is p/n 12130319 from GM and the cost on it is about $76. The one posted above by Dave89IROC seems to be a good deal to me. I think I might get one of those, too. My clip has been broken for some time.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
