sensor name
sensor name
Anybody know the part name for this sensor in the picture named (optispark)?
http://shbox.com/1/harness2.jpg
Re: sensor name
Originally Posted by toby360
I belive that the optispark plug is a pigtail... and I KNOW they charge an arm and a leg for this 1' pigtail. (300$ish!!)
https://www.casperselectronics.com/M...Category_Code=
Re: sensor name
You mean the little tit that fits into the bracket broke off? If that's all, use a nylon tie to hold it to the bracket. Maybe when it falls loose, it gets too close to the injector wires and starts to pick up electronic "noise", causing the code (what was the actual code you got?). A lot cheaper than buying a new harness. Unless the plug itself is somehow damaged or corroded, it shouldn't be a problem.
Re: sensor name
Originally Posted by Dave89IROC
nope, if it is for the 96 in his sig, dealer is around $90 IIRC, but it is half that here
Thats the one. I pulled it out and not only is it the clip but the wires right before the connector are eposed so gonna get a new one. Thanks a lot guys, tell ya what if new cars have more computer crap on them I feel bad for the furture mechanics lol.
Re: sensor name
It is p/n 12130319 from GM and the cost on it is about $76. The one posted above by Dave89IROC seems to be a good deal to me. I think I might get one of those, too. My clip has been broken for some time.
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
