semi high compression motor, what spark plug gap?
Old Aug 25, 2004 | 11:01 AM
MonkeyManZ28's Avatar
i have a fresh 360 ci lt1 it has the lt4 hot cam, ported heads, and all bolt ons, long tubes etc. i was wondering what the spark plug be on a motor that has between 11.1 to 1 and 11.3 to 1. i have the flat top pistons 11.1 to 1, stock deck height, heads havent been milled and i used the fell pro gaskets that i understand are slightly thinner than the stock gaskets. one other thing what plugs should i use, i was thinking ngk spark plugs, but does anybody any suggestions or comments?
thank you justin
Old Aug 25, 2004 | 11:25 AM
kmook's Avatar
Advanced Tech Moderator
Re: semi high compression motor, what spark plug gap?
Ngk are fine, I prefer autolite myself. .035 is what I gap at for a n/a engine.
mritter1965
Feb 9, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
94z28jbw
Sep 8, 2002 03:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
