Self aligning vs non self aligning
Old Feb 5, 2006 | 01:56 PM
Z28LT1_Just_Nasty's Avatar
Why would someone chose to go with one vs the other and vice versa? Does one make more power? Is one more durable etc? I considering going 1.6 and I don't know exactly the difference between the two except one aligns by itself.
Old Feb 5, 2006 | 10:12 PM
Josh'95Z28conv's Avatar
Re: Self aligning vs non self aligning
Go self aligning. You only have to pay a little more for guide plates, and have peace of mind. I will never again run SA rr's after my last incident
Old Feb 5, 2006 | 10:34 PM
Joe B's Avatar
IMO non-self aligning is the only way to go... unless ofcourse someone was in the situation where their heads had press in studs, and/or they never planed on removing the heads from the car for machining......some people also don't want the expense of guideplates and a good set of hardened pushrods, which NSA rockers always require.......many (including myself)feel that having a strong stationary steel guideplate and a hardened pushrod taking care of the rockers alignment, is far exceeding having just a small stop or fence built into the rocker sides......some of which are just aluminum(if the rocker is)
Old Feb 5, 2006 | 10:50 PM
So its cheaper to go SA? Why do most board members go with NSAs?
Old Feb 5, 2006 | 11:12 PM
Cmr0z28's Avatar
Safer, and more stable in higher RPM's.
Old Feb 5, 2006 | 11:15 PM
Joe B's Avatar
the last part of my post are some of the reasons
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
2QUIK6
Jul 15, 2015 07:46 PM
jasonduaine
Jun 4, 2015 09:29 AM
achipfef
May 5, 2015 10:20 AM
Hurin
Dec 13, 2014 07:38 PM
