security light on while driving
Old Apr 18, 2003 | 09:05 PM
Dan95TA's Avatar
On my way home tonight I got on it a little and my security light poped on. The car still ran fine then probably 5 min later the light went out. I scanned it before I turned the car off and there weren't any codes thrown. Anyone have a clue what would cause this?
Dan
Old Apr 18, 2003 | 09:38 PM
Probably the key or the contacts in the key cylinder are dirty or the leads from the cylinder are losing connection.
Old Apr 18, 2003 | 09:54 PM
Dan95TA's Avatar
How do I go about cleaning/checking that? Should I be very concerned?
Thanks shoebox
Dan
Old Apr 18, 2003 | 10:50 PM
Obviously, you can clean off the key. The cylinder could be cleaned with some electrical spray or whatever you could swab in there to wipe off the contacts. There is a 2 way connector under the dash that has wht/blk and ppl/wht wires in it coming from the column. It could be loose.
If the light comes on while driving, it won't shut your car down or anything. If it happens to be bad when you first try to start your car, then you probably will have a problem-you won't be able to start it.
Oncomingstorm22
Jan 22, 2015 07:15 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
30thZ286speed
Aug 3, 2002 04:54 AM
