Security light
Old Oct 1, 2013 | 11:41 AM
Chet1185's Avatar
Security light
My security light is on but not affecting anything. What would cause this?
Thanks in advance
Sent from my R800x using Tapatalk 2
Old Oct 1, 2013 | 12:54 PM
Re: Security light
Probably this:
Originally Posted by shbox.com
If the system detects a fault with the lock cylinder circuit after the engine is already running, the SECURITY lamp will light. The engine will be able to be restarted. This is called “fault enable mode”. (The system saw a good reading from the key at one point during a previous ignition cycle before the failure. So, it considers it a problem and not someone trying to steal the car.) When in fault enable mode, PASSKey protection is disabled until the problem is repaired. Once repaired, the SECURITY lamp will go out about 1 minute after the key is turned on. Fault enable mode will not shut down the engine while you are driving.
4th Gen LT1 F-Body Tech-PassKey/VATS
Old Oct 1, 2013 | 01:07 PM
Chet1185's Avatar
Re: Security light
I just read the whole section on your site and I have to say, I have no idea what I'm doing.
There have been a few times where the light would be on and I couldn't start it. I would leave the key in and after a few minutes the light went off. I hope it would be something easy. What would you suggest doing first? Do you think the "normal" bypass that everyone does would work?
Old Oct 1, 2013 | 03:04 PM
Re: Security light
You are probably having an intermittent key reading. Try the resistor bypass.
Old Oct 2, 2013 | 06:09 AM
Chet1185's Avatar
Re: Security light
I will try it, thanks rob
Old Oct 3, 2013 | 10:35 AM
Chet1185's Avatar
Re: Security light
Wow! Don't know what the hell is going on. I shut the car off and pulled the key and it kept running!
What would cause that?
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
