"Security" Light...
Old Jun 2, 2004 | 04:16 AM
Ryan's LT1's Avatar
"Security" Light...
Every once in a while, i'll go to start my car and it won't turn over, and when i pull the key out, the Security light stays on for about 3-5 minutes or something, then goes out, and then i can start the car fine. It happens pretty rarely, but still something odd none the less.
Is there a sensor/security protocol i don't know about?
Old Jun 2, 2004 | 04:27 AM
1 Nasty Bird's Avatar
The chip in your key is a resistor, the column has a wire going across that chip that measures the resistance, if its not right it triggers the security light. Your chip is probably dirty, just take a q-tip and some rubing alcohol and clean the edges, and if your careful you can stick the q-tip in the lock cylinder in the column and gently try to clean it. If the key has alotta crud on it try taking like a pin or something metal and fairly sharp and scrape the crud off. That should fix the problem.
Old Jun 2, 2004 | 06:21 AM
Ryan's LT1's Avatar
Yeah i knew the chip was a resistor but i didn't know exactly what it did. Learn something new everyday. Thanks!
Goody350
Jun 25, 2013 10:39 PM
jcamere94z28
Oct 25, 2012 04:17 PM
Randy Bilyea
Wheels and Tires
Oct 9, 2012 04:08 PM
Heatmaker
Sep 7, 2004 10:26 PM
