Secrets to making more torque at the dyno?
Old Dec 12, 2006 | 09:24 AM
trax's Avatar
My old setup (XE 224/230) made some pretty lousy torque at the wheels with 65K on the motor. Most heads/cam setups that I've seen have made more power.
Besides cam selection, what else do I need to look into in order to unlock more torque from this setup?
I had almost all the same parts with the old cam, except I used to run Hooker LT's and a Mufflex Y.
Heads
  • "Stage 2" ported by Combination Motorsports
  • Ferrea 2.00 / 1.6 valves, 3-angle valve job
  • ARP 3/8" studs and poly-locks
  • LT1 Iron-head gaskets
Valvetrain
  • CompCams 977 Valvesprings
  • CompCams locks, seats, titanium retainers
  • Cam Motion version of the GM847 (.575"/.595", 234/241)
  • Pro-Magnum 1.6 RR's
  • Chromemoly pushrods
  • LT4 Xtreme duty timing kit
Induction
  • GMPP stainless steel CAI
  • Trick Flow intake elbow
  • 52mm TB ported by NOMAD on CamaroZ28.com
  • TB airfoil
Exhaust
  • Kooks stainless steel 1-3/4" stepped longtube headers
  • Kooks Y-pipe
  • Hooker catback
  • T56 conversion, July 2003
  • McLeod street twin clutch, adjustable master cyl
  • Energy Suspension polyurethane trans mount
  • Pro 5.0 shifter, handle welded to base
  • SLP take-off posi
  • TA girdle
  • 4.10 gears
Also, here are some links that I read through:
how to get about 320 rwhp with good low end torque?
when should a xe230/230 112lsa make peak torque?
Someone please tell me why my car doesnt make more torque!
450lbs of torque
Best head/cam combo for maximum torque?
416.8 Hp 437.5 Ft/p
Thanks guys... now it's back to studying for finals...
Old Dec 12, 2006 | 09:42 AM
SStrokerAce's Avatar
How much did you make and how much do you want and where?
Bret
Old Dec 12, 2006 | 10:24 AM
teke184's Avatar
325-350rw torque from 3000rpm through 5900rpm doesn't seem bad to me.
not sure what you were expecting
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
canbaufo
May 5, 2015 03:43 PM
Feb 13, 2015 07:37 AM
