seams that rearend is shifted to one side
Old Feb 9, 2004 | 06:41 PM
blownbird01's Avatar
I just bought a set of zr1 all the way around. The rear is 17x11's. When I mounted the wheels, I noticed that the driver side wheel was sticking out further than the pass side. When I took some measurements, I found the rearend to be shifted to the driverside a half of an inch. This does not sound like alot, but thats the difference in the wheels tucking under the fenders. What can I do to fix this? Is this a common problem because I have ran across this on older cars? If this can't be fixed, I will be selling these wheels.
Old Feb 9, 2004 | 06:46 PM
fourthgen9534's Avatar
Sounds like probably a bent panhard rod, or possibly bad bushings. Take a look at the bar that's bolted to the rear end, and goes across and bolts to the body.
Old Feb 9, 2004 | 06:55 PM
Cmr0z28's Avatar
It's common with lowering or adding those wide rims. You'll need an aftermarket adjustable panhard rod. I recommend BMR and Spohn. www.bmrfabrication.com www.spohn.net
Installation is very simple too.
Old Feb 9, 2004 | 07:43 PM
JasonK94Z's Avatar
Ditto! Not a big problem to fix.
Old Feb 9, 2004 | 07:46 PM
I figured the bar was bent. I already ordered an adjustable bar. Just wanted to see what you got thought about it and if it was common. I've never come across this on a 4thgen before.
Old Feb 9, 2004 | 07:48 PM
Spinner's Avatar
My driver's side is about 1/2" farther out then passenger side. Just happens. Panhard bar will fix it.
Old Feb 9, 2004 | 07:51 PM
thanks for the info guys
Old Feb 19, 2004 | 04:04 PM
john97z28's Avatar
I hear that is a common problem on V6 models, haha!!! Make room in your garage for a REAL musclecar, we're starting that project soon.
Old Feb 19, 2004 | 06:23 PM
hey John, I hear that nuts & bolts increase horsepower when thrown into a new motor. I'll have to try that when I build your motor! HAHAHAHA!
Old Feb 20, 2004 | 06:47 AM
john97z28's Avatar
Oooooooohhh, point Ryan.
Old Feb 20, 2004 | 10:45 AM
My95Z's Avatar
same thing happended to me. I like the bmr one.. IT is a easy problem to fix like everyone else said!
mattstrike
Mar 11, 2015 07:33 PM
dale3in98
Feb 14, 2015 12:18 PM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
