Seals
Old Sep 16, 2003 | 06:02 PM
my94blackz's Avatar
Question Seals
I have got my car tore down to replace the water pump drive seal, my question is do i have to take the front cover off to get the seal out? Plus can i do the other 2 seals without pulling the cover off. What do i need to do? Thanks in advance.
Zach
Old Sep 16, 2003 | 06:19 PM
You don't have to remove the cover. Use whatever means to remove the seals without damaging the cover.
Old Sep 16, 2003 | 06:41 PM
RCF925's Avatar
You can buy or rent a seal puller which makes it a little easier.
Old Sep 16, 2003 | 06:44 PM
Mtrhds94Z's Avatar
Getting em out is the easy part
Get 2 WP seals [that one is hardest..]
Do a search.. [ there are a few helpful tips on installing the WP seal...]
Opti and crank seal aren't bad tho..
Old Sep 16, 2003 | 06:51 PM
Yes, a puller can help, but it is harder to use when there are shafts in the middle and in the way. No way you will be able to use a puller on the WP seal. There is no room.
Old Sep 16, 2003 | 07:52 PM
my94blackz's Avatar
Well i got it out guys and i purchased the front cover kit from advance and i busted the first seal as you guys said i would. Any place where i can buy the individual seal? 15$ everytime i bust a seal is gonna suck. The black side goes in toward the motor correct? thanks again guys.
Zach
Old Sep 17, 2003 | 05:54 AM
Mtrhds94Z's Avatar
94 Water pump shaft seal: GM 10217886
Also don't forget: Water Pump Drive Shaft Orings [2] GM 12553792
Old Sep 17, 2003 | 03:06 PM
revtime's Avatar
Maybe this will help.click me
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
