sealing CSR pump.. silicone?
Old Apr 30, 2006 | 09:38 PM
firebirdStud's Avatar
Lightbulb sealing CSR pump.. silicone?
Who relied only on that little rubber o ring seal for their CSR water pump? My housing was a little corroded, so I cleaned it up with a wire wheel on my dremel, but its still pitted. So, I was thinking of using RTV sealant too. I wouldn't use alot, just a nice bead around the whole thing to make sure I don't have a leaky b*tch when Im done. Yay or Ney?
Old Apr 30, 2006 | 11:05 PM
stroked383z28's Avatar
Re: sealing CSR pump.. silicone?
I've done it both ways and it didn't leak either way. I used rtv on my SS b/c there were a couple small imperfections in the sealing surface.
Old Apr 30, 2006 | 11:14 PM
was it a beotch gettin it back apart later, or have you gotten that far yet?
Old Apr 30, 2006 | 11:46 PM
Bersaglieri's Avatar
I used some RTV. Worked great. Not sure if I used the seal, I cant remember that part.
-Dustin-
Old May 1, 2006 | 12:08 AM
ibanez6rg's Avatar
I think I used both?
Old May 1, 2006 | 06:31 AM
chrism400's Avatar
The seal is holding fine on mine.
Old May 1, 2006 | 07:20 AM
Javier97Z28's Avatar
Moderator
Seal is fine on mine... it was the freeze plug on mine that leaked some. We just quicksteel'd it.
Old May 1, 2006 | 11:21 AM
I was thinkin of using the intake manifold sealant on that plug, then beat it in. Looks like I will do that now. So, even on a corroded face that little rubber o ring sealed good? interesting.
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Catmaigne
Jul 14, 2015 05:17 PM
