Sealant on water pump gasket?
Old Jul 10, 2004 | 11:48 AM
jdizzell's Avatar
I have the Fel-Pro water pump gaskets, do I need an sealant? Or just put it on dry?
Old Jul 10, 2004 | 12:04 PM
Eruption's Avatar
I usually use a small amount on the gasket just to stick the gasket to the pump. If you use it make sure you stick the gasket to the pump and not the block so when or if you have to remove the pump again the gasket will stay with the pump and not the block. This makes it easy to clean the gasket surfaces next time
Old Jul 10, 2004 | 04:15 PM
Bud M's Avatar
I've used RTV too with good results.
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Queens94z28
Dec 20, 2014 09:11 PM
