A Screw Question
Old May 22, 2004 | 06:27 PM
ping0317's Avatar
A Screw Question
When driving my car I notice that my center console will jump once in a while when I hit a bump. So I jacked my car up and looked underneath and to my finding I found out that the screw that holds the trans mount and cross memeber was stripped. Question, should I go to Menards/Home Depot and get a new screw or I need to get one from the dealership?
Old May 22, 2004 | 07:37 PM
Dave Feerst's Avatar
if the trans mount bolt is stripped you need a new trans mount. that are only like 15$ at any auto parts store.
Old May 23, 2004 | 09:56 AM
ping0317's Avatar
I just took out the screw that goes between the cross member and the trans mount. Question, when taking it out I was assuming that the screw would be a flat tip but to my suprise it is a pointy tip. Does it make a different of the type of tip the screw is?
Old May 23, 2004 | 11:30 AM
Bud M's Avatar
The pointed tip is there for assembly purposes. Any regular screw with the correct thread and length will do.
grgguy
17
Feb 23, 2015 07:57 PM
Chris Anderson
Jan 27, 2015 08:30 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
squarehead
Nov 21, 2014 08:02 PM
