SCR and DRC help
Old May 11, 2006 | 09:42 PM
jonlil77's Avatar
SCR and DRC help
can someone please figure my scr and dcr on my 383. I am getting different numbers with different calculators Here are the specs.383 with 1074 head gasket,5.85 rods,flat top pistons with -5cc reliefs,piston is .005 down in the hole,3.75 stroke,4.030 bore and 60cc heads and cc306 cam thanks
Old May 11, 2006 | 11:23 PM
rskrause's Avatar
Moderator
Re: SCR and DRC help
What is the intake valve closing point on the cam card?
Rich
Old May 12, 2006 | 04:30 AM
jonlil77's Avatar
73 at 0.006
Old May 12, 2006 | 07:03 AM
GetaZforgetGT's Avatar
When I run it through this site.
http://www.kb-silvolite.com/calc.php?action=comp
I get 13.1 SCR and 9.75 DCR
Old May 12, 2006 | 03:06 PM
jonlil77's Avatar
Hope this is not correct any others come up with the same numbers?
Old May 12, 2006 | 03:34 PM
Type_O_Negative_1320's Avatar
Static compression: 11.55:1
If you install the cam straight up (no advance or retard, already has 4* ground in):
Dynamic compression: 8.61:1
4* advanced:
Dynamic compression: 8.92:1
4* retarded:
Dynamic compression: 8.28:1
I added the last two in case you have a Cloyes timing set...it'll allow you to go 4* either direction.
Old May 12, 2006 | 03:42 PM
jonlil77's Avatar
stait up and that sounds muuuuch better thanks alot
arnie
Advanced Tech
24
Aug 14, 2005 08:39 PM
zto8
Nov 2, 2004 12:43 PM
zto8
Oct 28, 2004 08:24 PM
zto8
Oct 18, 2004 11:17 PM
