Scorpion roller rockers - will full body fit on stock heads?
Old Apr 10, 2012 | 12:38 PM
Blue96z28's Avatar
I've been doing a little research and it seems of the cheaper RR's the Scorpions' seem to be well liked. I am planning on turning a stock short block w/LE2 H/C to no more than 6300 and I am on a budget.
Does anyone know if the SCP1003 Full body 1.6 SBC 7/16 Rocker Arms will work on stock heads\valve covers with the normal baffle removal/minimal cutting on the covers? I would really like to run NSA 7/16 w/ guideplates and hardened rods. I just want to know if these will work otherwise I have to go down to the narrow body which are only available with 3/8 studs. I realize the SA narrow body 3/8 rockers would probably work for this RPM and power level but the cost is so similar I'd rather go big now in case I have to build the bottom in later and creep up the RPMs.
Any help would be appreciated.
Old Apr 10, 2012 | 12:41 PM
96capricemgr's Avatar
Re: Scorpion roller rockers - will full body fit on stock heads?
valvecover internal bracing will need to be trimmed. Think Golen has some pics on their site.
Old Apr 10, 2012 | 02:17 PM
Blue96z28's Avatar
Good deal. So you do you have experience with scorpions in particular or another 'full body' RR of similar size that you are referencing?
Old Apr 11, 2012 | 03:24 PM
Blue96z28's Avatar
Are all the other common RRs like the comp pro mags, proforms, etc classified as 'full body RRs' or 'narrow body'?
Old Apr 11, 2012 | 04:27 PM
Kevin Blown 95 TA's Avatar
Maybe confirm with the manufacturer whether they will work with the centerbolt heads, because that is the main area that gets in the way.
Old Apr 11, 2012 | 11:03 PM
Bersaglieri's Avatar
I'd spend the coin on Harland Sharp before Scorpion since they are closely priced. I see Harland Sharp as a step above Scorpion. Although I've always had the best luck with Comp Pro Mag, Ultra Pro Mag, or Stainless Pro Mags.
-Dustin-
Old Apr 12, 2012 | 10:33 AM
lt1-xjs's Avatar
The Comp Promag is a narrow body as well as any other claiming to be. They fit under the stock valve cover with slight trimming. I run the Scorpion Race series which is considered a widebody or std sbc rocker. I don't think you can run the stock cover. I use the Proform 141-131 cover which is 1/4" taller and has plenty of room.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
