Scoggin-Dickey LT-1 Shotrblock
Old Apr 30, 2005 | 12:16 PM
Andrew04ME's Avatar
I'll be in the market for a new shortblock soon. I saw this in their add in my GMHTP magazine. 4 bolt main LT-1 replacement for $1800. From what i gather it's not rebuilt, which is a bonus. This is probably 1000-1200 cheaper than what i could put together myself, and then i would have to worry about getting high quality machine work, which isn't guaranteed. Would probably add a hotcam and LE1 heads, and call it a day. What do you all think?
Old Apr 30, 2005 | 12:41 PM
97WS6Pilot's Avatar
Re: Scoggin-Dickey LT-1 Shotrblock
That is a good deal if they have good components. I cant find the $1800 short block on their website. Could you post a link to that short block so I can check out the components. I'm wanting to buy a built short block preferably 4 bolt main and then put LE1 heads and cam on it.
Old Apr 30, 2005 | 01:16 PM
LameRandomName's Avatar
You might want to double check your part numbers.
There are, as far as I know; only two LTx short blocks that Scoggin-Dickey sells. One is a 10.4:1 compression version and the other is an 11.8:1 version. Both cost $4,485.00
BTW, both are nice shortblocks and would make fine foundations for a new engine, although you can spend less money. There are also minor differences between those short blocks and the ones most people build. Nothing that will matter if you never plan to rebuild it, but the parts selection on the inside is slightly different.
Old Apr 30, 2005 | 02:22 PM
jkipp84's Avatar
I've seen the same ad, but it can't be found on their site.. Worth a phone call, that's for sure.
Old Apr 30, 2005 | 02:30 PM
1996LT1NY's Avatar
I'm pretty sure that is a stock GM short block. They used to have it in thier ad's for $1799 a few years ago. I had heard they were sold out quite awhile ago. Give 'em a call & see what they say
Old Apr 30, 2005 | 04:31 PM
mrz28 73/97's Avatar
The one for $1799 is a 4 bolt main Corvette replacement like the ones GM used to do warranty repairs. It has cast crank, pm rods and hyperucraptic pistons, that said for the price if you're not going to be spraying your car it makes for a stout street motor with a heads & cam package and you get 4 bolt mains to boot.
Old Apr 30, 2005 | 08:26 PM
Andrew04ME's Avatar
I happen to agree, especially for the price.
Old Apr 30, 2005 | 09:45 PM
Fastbird93's Avatar
Call me crazy but I thought that SDPC quit selling that stock 4 bolt shortblock because they only had a limited supply, and when they ran out that was it.
Old May 1, 2005 | 01:25 PM
Sunsceamer's Avatar
Are the pistons the same as in my 97? If so my engine was on a 150 shot for 2 years after jetting from a 100 TnT. I will call and buy one in less than 24 hours if shipping isnt that bad.I thought since it wasnt on line that they were gone myself.
Old May 2, 2005 | 04:07 PM
Sunsceamer's Avatar
I called today after seeing the ad in gm high tech and they said they are sold out.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
1995Blackz28
Jul 20, 2015 09:34 AM
