Scat crank
Old Nov 27, 2011 | 07:35 PM
my1994z28's Avatar
Scat crank
I recently purchased a scat 383 stroker kit for my lt1..part # for the crank is9-350-3750-6000L..can someone please tell me if this crank will work in my block..I know its a 1 piece rear main seal.Are our 92-97 lt1s internal or externaly balanced?I have a feeling i messed up on this purchase..It was a impulse buy at the time..
Old Nov 27, 2011 | 07:41 PM
Re: Scat crank
Stock LT1 is externally balanced, using a counterweight on the flywheel (or flex plate). But it's possible to build the engine either internally or externally balanced.
Old Nov 29, 2011 | 10:42 PM
MachinistOne's Avatar
Re: Scat crank
Yes, that is the correct one piece rear crank for the late model blocks - although that is one of the cheap cast ones. It can be balanced either internal or external depending upon the bobweight figured on all your components - it will either require a slug of mallory with a neutral flywheel, or a few large drill holes with a stock style weighted flywheel.
Jeff1904
Jun 5, 2016 05:00 PM
Z Power
Sep 19, 2015 11:19 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
