Scanner
Old May 12, 2010 | 09:30 AM
ssviper's Avatar
Scanner
What scanner do i need to buy for my 93z28.
Old May 12, 2010 | 10:15 AM
One that is capable of doing OBD-I scanning.
Old May 12, 2010 | 10:19 AM
ssviper's Avatar
What brand and who has them
Old May 12, 2010 | 11:20 AM
If all you need to do is pull the trouble codes, you can do it without a scanner, by shorting the ALDL pins, and flashing the codes on the SES light. Shoebox has a guide:
http://shbox.com/1/dlc2.jpg
As far as scanning the ECM for sensor readings, operating parameters, etc., you could use a hand held scanner, as Shoebox notes. You can find older Auto Xray OBD-I scanners on ebay or other sites. You can buy any number of new scanners that will read both OBD-II and OBD-I (optional cables often required). Auto Xray and Actron are just two of many sources.
Or, if you have a laptop, you can get free (for up to 20 uses) data logging software from TTS DataMaster:
http://www.ttspowersystems.com/DataMaster.html
You will need a cable:
http://www.akmcables.com/
Old May 12, 2010 | 12:14 PM
ssviper's Avatar
Thanks Injuneer
Nayr
Mar 3, 2023 08:34 PM
plattted
9
Sep 20, 2015 11:23 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
z28cam1993
Jun 15, 2015 07:32 AM
aj2494
Mar 12, 2015 10:17 PM
