scanned car: knock sensor circut
Old May 21, 2004 | 12:05 PM
94Zpower's Avatar
Angry scanned car: knock sensor circut
So I got my 94Z scanned and the knock sensor circut code came up so I swapped my stocker for an LT4 km and still have the problem! what else can I check or do...
Old May 21, 2004 | 12:19 PM
DTC 43 is what you have? This does not automatically mean the knock module.
With the connector off the KS, check for 5v on the harness terminal with key ON. Continue if that is good. If not good, check at pin D22 on back of PCM.
Key OFF. Connector off. Measure the resistance between the KS terminal and ground. Resistance should be between 3300-4500 ohms. If it is not, the sensor is faulty or the sensor is not making good contact with the block.
If all that is good, it might be the knock module or faulty pcm.
OBD-I Knock sensor GM PART # 10456126 ACDdelco #312-96
HectorM52
Jul 30, 2017 11:46 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
