Scanmaster w/ ODBI conversion
Old Nov 5, 2003 | 11:26 AM
ollie-99's Avatar
i converted from OBDII to OBDI how would i install the scanmaster?
same as obdI
Old Nov 5, 2003 | 11:36 AM
All you need to do is make sure you attach the white ScanMaster wire to the tan data wire that goes to the ALDL connector.
Old Nov 5, 2003 | 11:42 AM
ollie-99's Avatar
got a pic
Old Nov 5, 2003 | 12:50 PM
turbo_Z's Avatar
http://csce.uark.edu/~jgbertr/rb/dlc1.jpg
you want the black wire at #4, white at #9, red at #16
i found the easiest and cleanest install is far as hooking up the scanner is buying an OBD2 molded connector and wiring up the scanmaster to it so it can be unplugged if needed. like this. got mine from www.akmcables.com for around $10.
marlar98
Sep 12, 2018 07:18 AM
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Sep 19, 2015 07:53 AM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
