scaned my car today
Old May 1, 2004 | 06:12 PM
polcat1p's Avatar
scaned my car today
The scanner said my opti is grounded. Anyone know what that means?
Chad
Old May 2, 2004 | 09:08 AM
What was the exact code? The only codes directly related to the Opti are DTC 16 and DTC 36 for the low and high res pulses. "Grounding" sounds like one of the codes related to the ignition control module (ICM) - e.g. DTC 42, although this can relate to problems with the distributor.
Old May 2, 2004 | 11:34 AM
polcat1p's Avatar
It was code 42 EST grounded. Could it be my coil, because i never switched to a 94 coil when i converted my 93 motor into a 94. The connector pluged right in though.
Old May 2, 2004 | 07:54 PM
93-95 coils are all the same - dual-connector.
There is a fairly complex "logic tree" in the shop manual for sorting out all the possible causes of DTC 42. Almost impossible to describe.... you need to get a copy of the chart.
Old May 9, 2004 | 04:17 PM
Max 93's Avatar
where would you find a copy of this? I am getting a code 42 and can't figure it out.
Old May 10, 2004 | 12:58 AM
I could fax you a copy if you want. Send your fax # to my e-mail address.
Old May 10, 2004 | 07:57 AM
Max 93's Avatar
email sent. thank you.
Noenav
Mar 1, 2019 07:38 AM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
USAirman93
Nov 24, 2014 03:37 PM
