scan files
Old Feb 21, 2016 | 01:49 PM
blac94Z's Avatar
scan files
hey what's up you guys just wanted some feed back on this scan I ran with the new opti and plugs in and I still have a miss thanks 75-80% gas
File Type: csv
Old Feb 21, 2016 | 03:29 PM
Re: scan files
Before I download.... what is the difference in the three files? And what does "75-80% gas" mean?
Old Feb 21, 2016 | 03:49 PM
blac94Z's Avatar
Re: scan files
typo I have a miss around 75-80% throttle also I noticed there is no difference between the files
Old Feb 21, 2016 | 04:51 PM
Re: scan files
Do you look at these at all? You have 5 codes. I expect 26 - EVAP solenoid; 27 - EGR solenoid; and 29 - AIR pump circuit are due to deletions. But you have DTC 23 for an open circuit in the IAT sensor (reading 40-deg below zero), and DTC 48 for an open circuit on the MAF sensor (reading 470 gps).
Old Feb 21, 2016 | 09:45 PM
blac94Z's Avatar
Re: scan files
Yeah the prev owner took the mass air flow off and i have not got around to buying a sensor for the iat yet
Old Feb 21, 2016 | 10:53 PM
Re: scan files
When the MAF sensor fails (or is removed), the PCM defaults to the "speed-density" method of calculating mass air flow. The critical sensor inputs to a speed-density system are MAP and IAT. You have no IAT sensor signal. I'm amazed that a miss at 70-80% throttle is the only problem you have.
At a minimum, you have to fix either the IAT or the MAF. It isn't even worth looking any further at the log at this point. Is you IAT sensor even installed and connected?
Old Feb 22, 2016 | 11:49 AM
blac94Z's Avatar
Re: scan files
No sensor pigtail is there for the iat
Old Feb 22, 2016 | 12:24 PM
94Z28LS1toLT1's Avatar
Re: scan files
Bro so wat happened my beast is ready,can't get a hold of u
Old Feb 22, 2016 | 10:12 PM
Re: scan files
Better start looking for it or the wires, then. It's not going to find itself.
Old Feb 22, 2016 | 11:06 PM
Re: scan files
Yes definitely,I thought you ordered a new wire harness man
Old Feb 22, 2016 | 11:09 PM
Re: scan files
☺im confused I thought u have the sensor in the elbow but just need the wire bro,I still have the wire in my shed
Old Feb 23, 2016 | 01:06 PM
blac94Z's Avatar
Re: scan files
better start looking for it or the wires, then. :d it's not going to find itself.
well i reckon it wont lol
Old Feb 23, 2016 | 11:25 PM
Fatdog2's Avatar
Re: scan files
Hi blac94Z.Just want to ask what computer operating system you are running?I'm running windows 10 and i get error messages all over the place when trying to get DLOG.My mule computer seems to have a cheap vista install after a hard drive replacement that my brother in law gave me.I searched msn and the net for solutions but to no avail.Many thanks.
Old Feb 24, 2016 | 12:47 PM
blac94Z's Avatar
Re: scan files
win 7 my win 10 seems to have problems also with scan94/95
Old Feb 24, 2016 | 01:30 PM
Re: scan files
Wat up bro,when can I swing by to help u out,can't get through to ur phone
