sbc timing chain in lt1
Old Apr 19, 2005 | 01:00 PM
17WITHaBIRD's Avatar
I read that if I was doing a cam swap and have an electric water pump that I can run a standard sbc timing set. Is this true? I found from an old post that the cloyes true roller timing set works well. The part number is 9-3145. Anyone know about this, and is there anything I need to change because my car is a 94 OBDI? Thanks.
Old Apr 19, 2005 | 03:20 PM
sssalah's Avatar
Re: sbc timing chain in lt1
Yes, you can run this timing set with an electric water pump I have one but not sure about the part number, just make sure it's for a factory hydraulic roller which has a different camshaft bolt pattern than regular ones.
You'll have to change to the vented opti (95+) and somehow have a long pin on the camshaft 0.615-0.62".
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
