SBC swap into 94
SBC swap into 94
Car has an lt1... have a built SBC 383
to put in ... What all is required... k member I know... what else.. its carb'd.
PLEASE no comments on I wouldn't do that, or why are you doing it or anything like that.. if it doesn't pertain to my question please keep the opinions to yourself.
Thanks in advance,
Nelson
to put in ... What all is required... k member I know... what else.. its carb'd.PLEASE no comments on I wouldn't do that, or why are you doing it or anything like that.. if it doesn't pertain to my question please keep the opinions to yourself.
Thanks in advance,
Nelson
search for it...I found a few guys that are active on here that have carbed motors.....what type blower is it? I hope its not like a 8-71 or something cause I don't thing that will be too simple..
one tip I got alot of is go with the msa short billet dist and crab cap
Some of the guys I talked to had pics also
I found a guy on ls1tech that has one..about a 95Z carbed....he has a web page with a lot of pics and info on his set-up
Sorry to bring this up but I am putting a SBC 350 into my 94 firebird and I don't know what to do for mounts, does the LT1 block and sbc block share mounting locations? If so is all I have to do is use my lt1 mounts? I was under the impression that the LT1 mounts were different from regular SBC mounts but then someone told me that while they were different the blocks had the same mounting position. On the other hand though I have heard that the LT1 mounts are offset and the mounts don't use the same mounting holes as a SBC.
LT1s can use SBC mounts, but a SBC doesn't have the needed holes for LT1 mounts
BUT, since the difference is only on the pass. side, bolt it to the drivers side and modify the pass side mount to fit
How can you mod the passenger side? Can you just drill holes in it or do I need to wield more material to the base of the mount first before I can add the needed holes? Thanks for answering my question, your the first person who has gave me an answer here or on ls1tech.
CamaroZ28.Com Message Board > Technical Discussion > LT1 / LT4 Engine Tech > SBC swap into 94
heres the idea
SBC uses 3 bolts to atach the mount, two at the top, one at the bottom, in a triangle
LT1 has these 3, but one more behind the bottom one, the two center holes are shared between the 2 engines(the front lower hole on the LT1 is used to attach a brace for the A/C compressor)
do you have any fabrication skills? if so look into tthe smith motor mounts or madmans...you could make something similar but just make the block mount plate to fit yours
I got the moroso solid mounts but ended up returning them cause I couldnt figure out what I needed, the solid mounts are both the clam shell type thing but I need one of the clam shell style mounts and one of the ones that go around them? How would the Moroso mounts work?
