Sawtooth dyno graph
Sawtooth dyno graph
I finally got the text file from my dyno tuner with all the data in it for my dyno tune and put it into Excel. When I graph the HP & TQ it is very choppy. The Excel file can be found Here
What would cause a graph to look like this?
Here is the original thread about it. The numbers after the dyno tune were 349.3HP @ 6000 & 323.8 TQ @ 5250 on a Mustang Dyno.
That's an interesting thought about an ignition problem. I am running a MSD Digital 6+ for use with the NX wet kit. I am changing the spark plugs right now, so I will see how they look.
I didn't have the original scan of the dyno graph, so I took a picture of it with my digital camera and the link in the other thread now works.
I just got done changing the spark plugs from TR55 to TR6 and 1-5 looked pretty clean, but 6-8 were pretty brown and the tip that the plug wire presses onto wasn't screwed down tight. Do you think that could have an effect?
I can post a picture of the plugs if you want to see them.
Thanks.
Thanks.
tdigger9899
Sep 7, 2015 10:56 AM
