same pistons as reg 350?
Old Jul 21, 2007 | 04:03 PM
11secgen's Avatar
do lt-1's use standard 350 pistons?
Old Jul 21, 2007 | 07:46 PM
aboatguy's Avatar
The entire rotating assembly (for one piece rear main seal sbc) will fit. So the answer is
Generally YES.
Now if your looking at 13.5 to 1 pop-up pistons (dome, pop up whatever) they may not fit due to the lt1's small combustion chambers
Mike
Old Jul 22, 2007 | 03:47 PM
jclark311's Avatar
Same bore size but LT1 use a Mahle lightwieght hypertetic piston, with not much skirt.
Old Jul 22, 2007 | 06:28 PM
MachinistOne's Avatar
The rotating assembly is lighter on the LT1 like was said above - the pistons are lighter and hense the crank has more weight removed. If you try and use standard weight pistons you will have to add metal to the crank.
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
