is this the same cam??
Old Jan 20, 2005 | 08:39 PM
GR8RIDE_96's Avatar
p/n's 08-306-8 & 07-306-8
these are the comp cam 306 cam p/n's. the 08 is apparently for the TPI 350 and the 07 is for the LT1. Is it the "exact same" cam just different number?? can i use a 08-306-8 cam in my LT1??
Old Jan 20, 2005 | 08:41 PM
mustangmuncher's Avatar
Re: is this the same cam??
The cams are different, for the optispark, there is a dowel pin... and maybe another difference? But I do not believe that you can use the TPI cam in the LT1
Old Jan 20, 2005 | 10:23 PM
You answered your own question. The 08 cam is not an LT1 replacement cam. The lobe specs may be the same, but the machining on the nose of the cam is not.
Old Jan 21, 2005 | 10:52 AM
GR8RIDE_96's Avatar
thank you
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
