Saggy motor mounts? how to tell
Old Jul 2, 2003 | 09:08 PM
Stock Z's Avatar
Ok here is the deal, I just installed RK Sport headers, off road pipe, and hooker cat back. (btw sound great, calm at idle and cruise but screams at WOT) But on the passenger side, the flange on the header is hitting on the part of the front "frame" (maybe the k member) when the engine vibrates hard. So would new motor mounts lift the engine any or at least enough to give the collector flange a little more clearance? The mount have almost 150k miles on them so i'm sure they are worn but would it be that much?
Or should I just get a good pry bar and bend the header a little bit?
Old Jul 2, 2003 | 09:19 PM
QCKZ28's Avatar
i had some clearance issues with my headers, changed over to poly motor mounts and it solved the problem, mine were really saged after 70K miles.
Old Jul 2, 2003 | 09:58 PM
Stock Z's Avatar
Were you able to put the ply mounts on WITHOUT removing your headers, I had problems with some spark plugs that I don't want to remove unless I am putting on new heads.
Old Jul 3, 2003 | 12:37 AM
QCKZ28's Avatar
im not sure about installing them with headers on, i did mine while doin headers. IMHO i would not bend the header. changin the mounts should do the trick. also now when i rev my motor is doesnt rock in the engine bay, it rocks the car a little
jesse
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
