The saga continues!!!!!
Old Jul 23, 2004 | 11:27 PM
jdizzell's Avatar
Unhappy The saga continues!!!!!
Well…..after finally getting my valves adjusted right, I came across a new problem. I’m blowing a lot of smoke only at high rpms. No smoke at idle or even when I’m cruising up to 4,000rpms. But as soon as the rpms go over 4,000, smoke is just barreling out the exhaust. I also have no power at all through the whole rpm range.
My guess is I have bad piston rings. But then I would be blown smoke from idle also. So who knows, what should I look at first or test first?
Old Jul 23, 2004 | 11:49 PM
Loadre's Avatar
Re: The saga continues!!!!!
I don't know the rest of the story but a leakdown/compression test might be able to tell you a whole lot.
Old Jul 23, 2004 | 11:53 PM
jdizzell's Avatar
I had a blown head gasket and it took me about 4 days to adjust my valves right.
Old Jul 24, 2004 | 03:41 PM
slopokrodrigez's Avatar
Have you done a pressure test to the coolant system?? Does your oil or water level drop after a while? Is either of the 2 mixed?
Are you saying that you replaced the head gaskets and then adjusted the valves?
Old Jul 24, 2004 | 04:17 PM
jdizzell's Avatar
Yes. I had a blown head gasket, so I replaced it. Then I spent 4 days adjusting the valves just right. Now it feels like I have no power or pull through the rpm range and Im blowing smoke at high rpms.
Old Jul 24, 2004 | 04:25 PM
So what about the other questions? What color is the smoke?
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
