Safe To Use RTV On Header Gaskets?
Old Apr 28, 2004 | 09:06 PM
Kataklysm's Avatar
Well my copper header gaskets have 1 or 2 small leaks, if I put the copper RTV (supposedly 1200 degrees protection) will it melt off or do anything unwanted? Any info would be greatly appriciated, thanks.
Old Apr 28, 2004 | 10:14 PM
QCKZ28's Avatar
even with the high temp RTV mine melted off, i guess its just too hot, i havent had a leaking header since i bought some Percy Dead Soft aluminum gaskets
jesse
Old Apr 28, 2004 | 11:14 PM
97WS6SCharged's Avatar
Just a for instance, my EGT gauge generally reads about 1200 degrees at cruise, so the RTV isn't going to last very long.
Old Apr 28, 2004 | 11:19 PM
IrocSS85's Avatar
well all Ive heard is bad stories about those copper gaskets. Id just replace them w/felpro's if your worried about wasting time. if you got the time to spare, why not try it? make sure its high temp stuff though. I know that stuff works fine w/paper gaskets (cause Ive done it before on a cheap set of headers that warped the flange). you really shouldnt need that stuff for the paper gaskets though.
chris
Old Apr 29, 2004 | 01:30 AM
Red96Lt1's Avatar
My copper gaskets are doing fine.
Old Apr 29, 2004 | 01:54 AM
SiDeWaYZz28's Avatar
my copper gaskets suck baawwwwllllsss...leaks from hell...hatem never eva eva eva going to blow 4500 bucks for a fualty mr.gasket coppers gaskets
Old Apr 29, 2004 | 06:20 AM
Kataklysm's Avatar
Well if the RTV doesn't work I was planning on using a set of felpros instead.
Midnight_Z
Feb 16, 2016 09:36 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
Queens94z28
Dec 20, 2014 09:11 PM
